Zeige Ergebnis 1 bis 3 von 3
Thema: Gleichstrom auf Drehstromlichtmaschine
  1. #1
    Hallo Mini Gemeinde
    Ich bin soeben dabei meinen 1972 Mini von Gleichstrom auf Drehstrom umzurüsten, nun meine Fragen:
    Was muß ich mit dem Schwarzen Regler tun.
    Wo müßen die Kabel angeschlossen werden.
    Ist es überhaupt möglich mit dem Kabelbaum
    Über jeder Antwort bin ich Dankbar.
    Gruß Frank
  2. #2
    Hallo Frank,
    habe es zwar selbst noch nie gemacht, aber Keith Calver hat es auf seiner Website unter "Calver´s Corner", Rubrik "Electrical" unter "CHANGING FROM DYNAMO TO ALTERNATOR" gut verständlich beschrieben.
    Hoffe, du kommst mit Englisch klar.
    Zitat Zitat von KC
    CHANGING FROM DYNAMO TO ALTERNATOR 1 September 2000 / amended 15 May 2007
    Completing this change successfully, easily and neatly is pretty straightforward on a Mini. The alternator contains the regulator and cut out functions within it’s casing, so makes the regulator box used with a dynamo redundant. However, it is useful to retain the box itself and it’s connectors. It acts as a terminal box to make the installation neat, avoiding the messy and awkward soldering/taping together bunches of wires. It also maintains a period look, plus makes reversal easy should this be needed in the future.
    Disconnect the battery and remove the black regulator box from the car - taking care to make a note of or label each wire removed with it’s original terminal connection. Fit the alternator using the necessary rear support bracket (part no. 12G1053), as the alternator is shorter than the dynamo. The relevant belt (GCB10825) is also needed. The alternator has a smaller diameter pulley to drive it at a higher speed than a dynamo, giving better output and therefore battery charging at lower engine speeds.
    Take the regulator box cover off and dismantle it. Remove all of the coils, contacts and connections to the blade terminals on the bottom of the unit, but retain the blade terminals. Double check that all connections to the terminals are removed including the one to the 'E' terminal, then using some heavy cable - 2.5mm or larger - solder links between terminals A, A1, and D, connecting all three together. Now solder a link between terminal F and E. Replace the box in the car and re-connect all the wires to their relevant terminals except the ignition warning light wire (brown/yellow) which must now be connected to terminal E. Connect the ex-dynamo wires to the alternator - large connector to the large terminal (output connection) and the small one to the small terminal next to it (sensing terminal).
    If the car being converted was already negative earth, re-connect the battery and away you go! If the car was positive earth, you will need to reverse the connections to the battery and swap the connections on the ignition coil.
    If there is a radio or cassette player fitted, check to see if these can be re-connected as negative earth. If not, then unfortunately they will need replacing. Everything else should work as normal.
    Hier noch der Link zu der Seite.
    Ich habs getan... :p
    Hab den Schaltplan studiert und den alten kabelbaum umgestrickt...war recht einfach. :)
    Beschreiben KANN ich es aber nicht anständig...
    *** Die Signatur ist in Urlaub ***
Themeninformationen
Users Browsing this Thread
Ähnliche Themen
  1. Eiszeit.... (Funstuff)
    By mini35 in forum Off Topic
    Antworten: 3897
    Letzter Beitrag: 19.03.2014, 18:05
  2. Startprobleme:Batterie lädt nicht mehr auf?!
    By Eilmsen in forum Elektrik
    Antworten: 61
    Letzter Beitrag: 26.03.2008, 19:46
  3. Sensationell - der erste Umrüstsatz auf EURO2 in Sicht!!!
    By chelgringo in forum Mini Discussion
    Antworten: 36
    Letzter Beitrag: 27.03.2007, 09:49
  4. Neue Gesetze ab 01.01.2006
    By Meister-Mini in forum Off Topic
    Antworten: 5
    Letzter Beitrag: 04.01.2006, 09:50
  5. Antworten: 15
    Letzter Beitrag: 12.12.2005, 00:31
Forumregeln
