Seite 10 von 12 ErsteErste ... 8 9 10 11 12 LetzteLetzte
Zeige Ergebnis 91 bis 100 von 118
Thema: An English HillClimb rebuild.
  1. #91
    fitted
  2. #92
    today was doing wiring wile watching some Macgyver
    and some cooling
    i cant get used to this heat.
    so i sorted a second starter switch
    and added wires for the wiper so that it will park and i hope soon have a single wipe.
    but most of today was unwrapping wires and re-wrapping them and unwrapping then when you remember that you forgot a wire that needs to be there.
  3. #93
    Hey Nicklouse.
    Nice pics from a good project. Respect.
    One question. Are you sure your grooved and drilled brake discs are mounted the right way. I've seen them often mounted the opposite direction.
    CU ;-)
  4. #94
    Zitat Zitat von Blech Bernd Beitrag anzeigen
    Hey Nicklouse.
    CU ;-)
    good question and i could understand your confusion. yes these are fitted the correct way around. But you will see other brakes with groves or holes machined the other way. it all comes down to the makers and the use and even the year that they were made.
  5. #95
    today was adding a switch to get the wiper working as required.
    https://youtu.be/gIPq3_tG77c
    Geändert von Nicklouse (03.06.2018 um 23:47 Uhr)
  6. #96
    final job this weekend was rear view mirrors
    still want to tidy up the front area .
  7. #97
    next delivery
    unfortunately the tap was undersized.
    this should have been 14mm
    so go to a shop and buy one.
    check size
    yes.
  8. #98
    so what was this for.
    not through enough need a plug. mmmm VW T4 sump plug
    will work as a drain plug.
    fitted
    wired up
    so there is a thermo switch on the cold side of the radiator and a switch in the car for manual override.
    now to find some 50mm ducting.
  9. #99
    Dabei seit
    01 2002
    Ort
    N 37° 14.410' W 115° 48.700
    Beiträge
    7.618
    Just for info:
    The undercutted tap was for pre-cutting by hand. It's signed with one groove at the top. And there should be usually a set of 3 tools...
    The other tool is for using in a machine and so it's a all in one tool. By hand it could need a lot of power and sweat
    So you can pre-cut with the small one (better centering) and afterwards with the other one.
    Geändert von J&A (15.06.2018 um 09:57 Uhr)
    POWER!!!!!!!!!!!!
    Jeremy Clarkson
  10. #100
    Zitat Zitat von J&A Beitrag anzeigen
    Just for info:
    thanks, this is kinda what i guessed after. but it was not the info i got from the info in the advert. some ways this will be be relating to what i was expecting through experience and poor technical German ;) i was expecting a Taper tap. would finish at full thread size.
    door mirrors finished off
    for now.
Themeninformationen
Users Browsing this Thread
Ähnliche Themen
  1. Faltdach Old-english-white
    By mr.tailor in forum Karosserie
    Antworten: 1
    Letzter Beitrag: 13.07.2009, 00:38
  2. Johnny English
    By dougie in forum Off Topic
    Antworten: 4
    Letzter Beitrag: 30.06.2008, 13:09
  3. Mini-Presentation English
    By Fox45 in forum Mini Discussion
    Antworten: 1
    Letzter Beitrag: 10.06.2008, 20:09
  4. English für Runaways oder so!
    By svenismk2 in forum Off Topic
    Antworten: 3
    Letzter Beitrag: 20.06.2007, 23:12
  5. Lackstift *old English white*
    By suomimini85 in forum Karosserie
    Antworten: 1
    Letzter Beitrag: 06.10.2004, 16:39
Forumregeln
