Seite 15 von 16 ErsteErste ... 5 13 14 15 16 LetzteLetzte
Zeige Ergebnis 141 bis 150 von 152
Thema: An English HillClimb rebuild.
  1. #141
    had a delivery from KAD
    the missing bits
  2. #142
    swapped out the studs on the rear hubs as the fitted ones are not long enough
  3. #143
    new springs for the rear shocks
  4. #144
    colour coding the SuperFins
    first coat
  5. #145
    in the meantime some work on some collected parts.
    transfer-house breather opened up and threads cut.
    setting up the steering parts
    sorting the rear silencer
    with new welder setup for stainless welding.
    very good welder. makes it easy.
  6. #146
    Ok so the rear end is back together
    had an issue as to how to sort out the ARB to the arms as the ARB was too wide of the mounting point on the pins was too narrow.
    after thinking it around a few times it will be sorted with 2 extra 1/2 male rose joints and some MountainBike shock reducers.
    the other two are currently on the end of the steering rack but they will sit alongside the shock with a small spacer between.
  7. #147
    Niceeee!!!
    Mit Null Ahnung richtig weit gekommen:thumpsup:
  8. #148
    well not been able to do much as i have been off work with Bronchitis but back at work on Monday so i thought i would put some stuff together as i was bored.
    might look at the front-end over the weekend.
  9. #149
    bolted some other bits together for fun
  10. #150
    right on to the strip down.
    front off. need to change the floor fixing as it is in the way.
Themeninformationen
Users Browsing this Thread
  1. Faltdach Old-english-white
    By mr.tailor in forum Karosserie
    Antworten: 1
    Letzter Beitrag: 13.07.2009, 00:38
  2. Johnny English
    By dougie in forum Off Topic
    Antworten: 4
    Letzter Beitrag: 30.06.2008, 13:09
  3. Mini-Presentation English
    By Fox45 in forum Mini Discussion
    Antworten: 1
    Letzter Beitrag: 10.06.2008, 20:09
  4. English für Runaways oder so!
    By svenismk2 in forum Off Topic
    Antworten: 3
    Letzter Beitrag: 20.06.2007, 23:12
  5. Lackstift *old English white*
    By suomimini85 in forum Karosserie
    Antworten: 1
    Letzter Beitrag: 06.10.2004, 16:39
