Möglichst neu oder im Neuzustand...
CZG5254 - DOOR STRIKER PLATE MK3
MSA1147 - MIRROR INTERIOR STAINLESS STEEL 6"LONG PRE 1996 CARS
5L954 - WIRING LOOM S"MK3 and 998cc 70-72 PVC DYNANO(310)
JFF10003 - HEATER CABLE FLOATING IN LINE PLASTIC HEATER VALVE 88-91
MSA344-3 - STARTER SAFETY PANEL PUSH BUTTON WITH 3 SWITCHES
13H6444 - WIPER SWITCH MK3 2 SPEED
21A2660 - INDICATOR STALK MK4 1984 ON L/H/S (LHD-76 TO 89)
13H6010 - NUMBER PLATE LIGHT SEAL
1B9100 - INDICATOR LAMP SIDE CLEAR GLASS 52338 USES AK606021 CLIP
5L1159 - BATTERY BOLT FRONT WITH A HOOK END 5.5mm long (2.25")
ADA5671 - DOOR CHECKSTRAP MK III ONWARDS
ADU5728 - STARTER SOLENOID 4 TERMINAL MINI 83-85 +ALL METRO
500929 - HEADLAMP RIM CHROME ON STEEL GENUINE ROVER
GWW404 - WINDSCREEN WASHER T PIECE 3mm
5L875 - WIRING LOOM MK2 ON REAR HEATED SCREEN PLASTIC COVERED
12G2534 - CYLINDER HEAD HEATER TAKE OFF
SP227 - PETROL CAP WITH ASTON LOOK,FITS ONLY ROVER LOCKNG CAP PRE 97
2A6215 - INDICATOR STALK MK1 INDICATOR SWITCH (31945)
GSD101MS - SPEEDO CABLE MINI 26"LONG FOR CENTRAL SPEEDO
CZH1666 - DOOR MOULDING OUTER WITH SEAL RH EARLY MK3
YTA10037 - BATTERY CABLE LEAD 127"LONG 1990 0N
CZH701PA - WINDOW WINDER HANDLE BEZEL BLACK SINGLE
GWW1192 - WINDSCREEN WASHER PUMP.FITS GWW940&GWW935 EXCEPT TWINPOINT
GWW935 - WASHER BOTTLE MINI (Oct 1988-2000)with cap
14E3386 - MKI & S SWITCH PANEL GREY
5L888MS - BATTERY EARTH STRAP 12"-13" LONG
24A1466MS - WINDSCREEN FILLET SILVER STRIP (Front or rear)
21A2329 - CHOKE CABLE RUBBER TYPE, PULL&TWIST, UP TO 1987
8G6027 - STEERING COLUMN COWL Mk1
88G221 - HEATER TAP GASKET
9403 - HEADLAMP RUBBER SEAL RING
2A9129 - SWITCH WIPERS Mk1 Mk2 & Early Mk3 (31780)
FZX3054 - CARBURETTOR TWINS HS4 KIT LESS FILTERS
CZH627 - DOOR STRIKER MK 3
M90997 - FITTING KIT L/H GAM216/108 TO 80-ON
1H9077 - SWITCH LIGHTS Mk1 Mk2 & Early Mk3 (31788)
13H337 - IGNITION SWITCH DASH MOUNTED
MS389 - WASHER JET TWIN JET, BLACK,NUT TYPE,WSB128
14A9907 - SPEEDO COWLING OVAL TRIM
CHM373 - HEATER CABLE PLASTIC KNOB
CGA2835MS - DOOR SURROUND SEAL MK3 WITH WIND UP WINDOWS TO 1996
24G1345 - IGNITION BARREL MK I & II
21A2454 - HANDBRAKE QUADRANT DRY SUSPENSION
CKE10018 - SEAL FOR BOOTLID 1988 to 2000 fits to body
CZH1785 - DOOR AND BOOT HANDLE SET CHROME(WIND UP WINDOW CARS)
CZH3529 - DOOR LOCK DISC LH
CZH1719MS - WINDSCREEN RUBBER ALL MINI TO 1991 WITH LAMINATED SCREEN
PV302 - INSERT CHROME FOR WINDSCREEN ON ROLL 30 METRE
GVC2134 - HANDBRAKE CABLE,REAR SECTION MK4/1976.>
BC50GWW801 - WINDSCREEN JET WITH TWIN CHROME NOZZLES AND BOLTS ON
CZH3528 - DOOR LOCK DISC RH
MSSK1011 - TRIM INTERIOR KIT BLACK 2 DOOR,2 SIDETRIM PANELS
RTC465 - HEADLAMP RIM SCREW STAINLESS STEEL CROSSHEAD TYPE
C-22A1752 - GEARLEVER QUICKSHIFT GENUINE KAD LATEST TYPE FOR ROD CHANGE
C-AJJ3331 - WORKS L/H/D DASH
SV2016A - SUNVISOR MINI 1970 ON PLAIN BLACK
