Folgende Teile werden nicht mehr gebraucht
und stehen daher jetzt zum Verkauf:
MED 1.5 ROLLER ROCKER ASSEMBLY
The best 1.5 roller rocker assembly on the market.
MED`s rocker set comes fully assembled with alloy rocker spacers and alloy end washers with split pins fitted.
The rocker shaft is up-rated from standard 14mm to our large 17mm diameter to give a greater surface area to contact between the shaft and the rocker arm.
The rocker arm is CNC machined from aerospace 7075 alloy and anodised gold.
Rocker posts are also made from a high quality steel and chemically black coated.
To further enhance the quality of this rocker assembly we fit larger 3/8 UNF adjusters along with lightweight 'K' lock nuts.
Neu und unbenutzt!
Preis: 250,00 € (inkl. Versand)
Link:
http://www.med-engineering.co.uk/catalogue/cyli…-1-5-rocker-set
