Beiträge von JEMI
...gekauft
Danke Christian und Gruß,
Marco -
Noch zu haben
...verkauft an forcker!
Danke Richard und Gruß,
Marco -
Kostet neu bei Swiftune umgerechnet 160 Euro, also warum von dir um 180 kaufen? Ist preislich noch was machbar?
Kostet bei Swift 147,60 Pfund (inkl. VAT) zzgl. Versandkosten aus GB...!
wie kommst Du auf 160,00 EUR (inkl. Versandkosten D)? -
...VERKAUFT an CHPH!
Danke Christoph und Gruß,
Marco -
Folgende Teile werden nicht mehr gebraucht
und stehen daher jetzt zum Verkauf:SWIFTUNE Duplex Vernier Timing Gear Set
Aluminium centred, infinitely adjustable Duplex timing set has steel outer gears for ulitimate durability. Optimised gear design to minimise chain slack with the resulting improvement in camshaft and ignition timing scatter. Cam gear weight - 520 grams: Set includes countersunk screws.
Race proven.Neu und unbenutzt!
Preis: 100,00 € (inkl. Versand) -
und stehen daher jetzt zum Verkauf:SWIFTUNE SW5-07 Billet Road Camshaft
The SW5-07B is the ideal road camshaft; below 5500rpm it produces more power than the 286 profile. On average you will spend 90 per cent of your road driving below 5500rpm.
The SW5-07B as featured in the Mini Films ‘Ultimate A-Series Engine Builder’ DVD. Combined with 1380cc. 1.5 ratio rockers, L3 head and a single HIF44 produces over 100hp and over 100ft/lbs of torque pulling with wide on throttle below 2300rpm!
The same engine used with Twin H2 1.25" SU's will pull from 1800RPM with wide open throttle!
Thousands of SW5-07B cams have been sold for a huge range of engines from: 850cc to 1460cc, twin and single carburetters, standard and 1.5 ratio rockers, SPi and MPi injection, turbo and supercharged.
LATEST SW5-07B camshafts are now machined from custom steel billet! No more aggravation with exchange camshafts, just a brand new core designed and produced at the right cost and the highest quality steel with specific profile shapes to suite road camshaft to eliminate excessive grinding of race x-drilled blanks and removing the vital surface hardening. The end result is a camshaft with deeper surface hardening and superb wear resistance.
The SW5 cam has been a huge success with thousands sold yet development work will never stop. The latest Swiftune SW5-07B camshaft was developed using Lotus Engineering's latest valve train computer software to enhance the cam profile. Further gains in bhp and torque have come from using the latest CNC cam grinding technology to machine the SW5 cam to much closer tolerances which are so important for achieving the optimum dynamics of the cam profile. The same machine is grinding cams for WTC, WRC all the way to Formula 1!
[The SW5-07 is Swiftune's exclusive design and is not available from any other source]Neu und unbenutzt!
Preis: 180,00 € (inkl. Versand) -
und stehen daher jetzt zum Verkauf:MED 1.5 ROLLER ROCKER ASSEMBLY
The best 1.5 roller rocker assembly on the market.
MED`s rocker set comes fully assembled with alloy rocker spacers and alloy end washers with split pins fitted.
The rocker shaft is up-rated from standard 14mm to our large 17mm diameter to give a greater surface area to contact between the shaft and the rocker arm.
The rocker arm is CNC machined from aerospace 7075 alloy and anodised gold.
Rocker posts are also made from a high quality steel and chemically black coated.
To further enhance the quality of this rocker assembly we fit larger 3/8 UNF adjusters along with lightweight 'K' lock nuts.Neu und unbenutzt!
Preis: 250,00 € (inkl. Versand)Link:
http://www.med-engineering.co.uk/catalogue/cyli…-1-5-rocker-set -
und stehen daher jetzt zum Verkauf:MED VERTO ULTRA LIGHT STEEL CLUTCH ASSEMBLY
MED´s first stage of verto ultra light steel clutch assemblies. This package utlilises the solid turbo clutch plate which is ideally suited to fast road use. Coming fully built up and dynamically balanced with the following components.
MED VERTO ULTRA LIGHT ST1
M E D ultra light steel flywheel
Turbo solid clutch plate
Heavy duty clutch cover
New clutch centre
6 x cover bolts
Dynamic balanceNeu und unbenutzt!
Preis: 320,00 € (inkl. Versand)Link:
http://www.med-engineering.co.uk/catalogue/clut…ultra-light-st1 -
kann man sowas irgenwo im TV Sehen ? Oder im Netz ? Habe am 16.04. meinen 40. Geburtstag und kann leider nicht dahin ...:-)
MfG, Dirk
Hallo Dirk,
leider überträgt noch kein TV-Sender unsere spannenden Veranstaltungen.
Wenn Du jemanden kennst, der jemanden kennt,...
...dann verhandeln wir gerne um die Übertragungsrechte ;):D:pGruß,
Marco -
...richtig was los in Sachen "Mini" am Hockenheimring...!!!
Mit 21 Teilnehmern in der BCT sind spannende Wertungsläufe garantiert.
Hier die aktuelle Starterliste:Gruppe 2, verbessert
201 Detlev Wassong
205 Ken Welch, GB
211 Gemma Morris, GB
212 Rolf Brack
213 Phil Harvey, GB
214 Thomas Gaspers
216 Alberto Pinna
217 Dieter Franke
218 Gordon Scott, GB
223 Jörg Hoffmann
229 Konrad Beckmann
231 Wolfgang Drixelius
252 Stephan Keiselt
255 Marco Teuscher
259 Manfred Laudor
260 Cüneyt Cuhalar
268 Heinz-Peter RosenfeldGruppe 1, seriennah
291 Jürgen Kohlhaas
292 Silke Wernecke
295 Sebastian Wallner
299 Timo LojewskiWer nicht kommt, wird was verpassen;)
Gruß,
Marco -
Hallo liebe Freunde der BRITISH-CAR-TROPHY,
ABARTH-COPPA-MILLE und NSU-TT-TROPHY,die neue Saison verspricht bei allen Events ein erfreulich volles Starterfeld.
Für die 7. Hockenheim-Historic am 16.04. und 17.04.2011 haben sich
rund 55 Teams, darunter viele der bekannten "Mini-Treter", eingeschrieben.
Der "Kampf der Zwerge" wird ausgetragen um den "Großen Preis
der Fa. Gruppo Ricambi Bielstein", die den großen Gesamtsiegerpokal
stiftet (http://www.bielstein.com).Am Samstag findet das Training (09:00 Uhr) und
der 1. Wertungslauf (14:25 Uhr) statt.
Der 2. Wertungslauf (17:20 Uhr) wird dann am Sonntag ausgetragen.
Wir befahren den kompletten F1-Kurs (4.574 m).Die Teilnehmer und Fahrer der BCT hoffen auf Eure Unterstützung.
Ein spannender Wettbewerb ist garantiert
Also bis dahin und Gruß,
Marco -
Ops...
Hi Ralf,
wirklich viel los im Moment... habe ich glatt vergessen...
Bin am Wochenende in der Halle und suche Dir die Nummer raus.
Melde mich dann nächste Woche!Gruß,
Marco -
Hi Stefan,
die bis jetzt fehlende Antwort ist sicher nicht mit Vorsatz zu begründen
die Saison-Vorbereitungen laufen bei allen Teilnehmern auf Hochtouren!!!
Auch bei den "Verantwortlichen"
Tipp am Rande:
Die BCT steht auch in diesem Jahr auf der Techno Classica in Essen
für Fragen und Antworten zur Verfügung.
Der Stand ist "wie immer" in der Galerie zu finden...
Dort wird Dir sicher geholfen :thumpsup:Mann sieht sich!
Gruß, Marco -
Hallo Ralf,
Nöö...
Spaß, ich suche Dir die Farbnummer raus und
sende Dir die Tage eine PN.Gruß,
Marco -
Hallo Jan,
ich nehme die beiden HIF zum angesagten Preis.
Bitte Bankverbindung per PN...Danke und Gruß,
Marco -
Hallo Jan,
habe Interesse an ein paar Teilen.
Bitte sende mir kurz Deine Tel.Nr.,
ich melde mich dann bei Dir;)Danke und Gruß,
Marco -
Ist eine tolle Sache...
...gefällt mir sehr gut.Gruß,
Marco
