KAD: Alu-Schwingen und Alu-Radnaben
  • Zum Verkauf stehen folgende Teile:
    Ein kompletter Satz KAD Aluschwingen
    http://www.kad-uk.com/mini-parts/min…n?product_id=22
    KAD Mini Swing arms, alloy with 3/8" stub axle pin.
    For use with dry rubber cone suspension!
    KAD Mini alloy rear swing arms (3/8):
    •sand cast in aluminium alloy L169
    •high strength alloy with good ductility
    •lightweight: half the weight of a standard steel arm and is suited to light road use, rallying, sprint, hill-climb and heavy circuit use
    •compatible with either conventional rubber cone or coil over suspension systems
    •choice of standard 3/8 dia or 1/2 dia stub axles for coil over damper application (these are 3/8" dia).
    Preis: 400,00 EUR inkl. Versand
    Ein Paar KAD Alu Radnaben, komplett inkl. Radlager und Bolzen
    http://www.kad-uk.com/mini-parts/min…n?product_id=27
    KAD Alloy rear hubs:
    •KAD's rear alloy suspension hubs,
    •CNC machined from high strength 2014A alloy
    •half the weight of the standard steel hub
    •compatible with the Timken type taper bearings.
    •Use with rear brake drums
    •Complete with wheel studs
    Preis: 120,00 EUR inkl. Versand
    Diese Teile sind gebraucht, aber in sehr gutem Zustand!
    Marco
  • In die Radnaben könnt man sicher auch noch nen 4x100 LK bohren oder?? Interesse besteht.
    Meld dich mal wenn du meine Handynummer noch hast.
    Gruß Daniel :cool:
