Zitat von minimoke68
Hallo in meinem Motorenbestand ist z.b. einer Stösselstangenabdeckung
schraubbar ,motorplättchennr. 9FD....... was jetzt ?? minimoke 68
Dann hilft das vielleicht weiter:
997 Cooper
9F/Sa/H101 to 2637 except 19201 to 20410 (became 1070S)
998 Cooper January 1964 onwards)
9FA/Sa/H Mk1 Austin pre closed circuit breathing
9FD/Sa/H Mk1 Morris up to engine number 1934, all Austin Mk2 closed circuit breathing and
Morris Mk2 from engine number 1935-33660 with closed circuit breathing
9FD/Xe/H 4 syncro gearbox introduced
99/-/H Last of manufacture 1969
Cooper S variants
970cc
9F/Sa/X Engine numbers 29001-29003 with Tecalamit filter
9FD/Sa/X Closed circuit breathing introduced with Tecalamit filter
9FE/Sa/X Closed circuit breathing, oil filter with oil light switch introduced
9F/Sa/X Engine numbers 29039-30029 Purolator oil filter with oil light switch and closed
circuit breathing
1070cc
9F/Sa/H Engine numbers 26501 to 33660 and 19201 to 20410
9FD/Sa/H Engine numbers 33661 to 33948 with closed circuit breathing and oil light switch in
oil filter head
1275cc
9F/Sa/Y Engine numbers 31001 to 31504 pre closed circuit breathing with Purolator oil filter
9FD/Sa/Y Closed circuit breathing with oil light switch on filter housing after engine number
32178
9FE/Sa/Y Closed circuit breathing with oil light switch on Purolator filter housing and piston
design change
9F/Sa/Y From engine number 32378 onwards, cosed circuit breathing with Purolator filter
with oil light switch, Aeg510 camshaft introduced at engine number 40006, cross-
drilled EN40Bcrank at engine number 42730 and metal dipstick tube at engine
number 42548 onwards
12H397 Cooper S Mk3 with dynamo, negative earth and Tuiftrided EN16T crankshaft
12H398 Cooper S Mk3 with alternator, negative earth and Tuftrided EN16T crankshaft
Note: Only Cooper S engines with prefix '9F' had EN40B forged steel, nitrided crankshafts. All other A-series engines had EN16T steel crankshafts which were only Tuftrided on Mk3 'S' and Austin 1300GT (ADO16) and were stamped 12G1683.
