Australien Moke Mit Daihatsu Sirion Motor
  • ok! so things are almost complete,
    car is finished basically, went and took it to the wheel aligner today, still needs to get the rears adjusted properly though, needs a steering column shroud modified (my dremel shit itself), a bezel for the speedo cluster and some carpets made up
    the TAC (transport authority Commitee Representative) comes to inspect it on thursday, and hopefully by then i have my engineers report finished and then i can get it registered on friday or monday
    here are the pics you have all been waiting for :)
    1982 Leyland Mini Moke mit Daihatsu Sirion Engine
  • Introducing my Finished 1982 Leyland Moke with Daihatsu Sirion Engine Conversion
  • Congratulations!
    At last a video with the engine running would be great!
    Have a good Time, Dude!
    Best regards, Ide
    1978er 1000er Leyland
    1990er 1275 Cooper "Proud"
    1986er 1000er "Chelsea"
    1991er Cooper SPI "Charles"
  • ill see what i can do.. ive recently come across a clearance issue that i need to sort out at some stage, i also need to purchase a new or reconditioned alternator
  • And if you fixed the pipe from the valve-cover to the inlet....
    your Engine would be Run smoother.
