MED 1.5 ROCKER SET
http://www.med-engineering.co.…ockers/med-1-5-rocker-set
The best 1.5 roller rocker assembly on the market by far, sold to many top Mini parts suppliers around the globe.
The rocker set comes fully assembled with alloy rocker spacers and alloy end washers with split pins fitted.
The rocker shaft is up-rated from standard 14mm to our large 17mm diameter to give a greater surface area to contact between the shaft and the rocker arm.
The rocker arm is CNC machined from aerospace 7075 alloy and anodised gold.
Rocker posts are also made from a high quality steel and chemically black coated.
To further enhance the quality of this rocker assembly we fit larger 3/8 UNF adjusters along with lightweight aircraft specification 'K' lock nuts
War nur rund 500km im Einsatz, Zustand neuwertig. Bei Fragen bitte PN an mich.
Preis: 220,00 € inkl. Versand.
Marco
