The "special fork tool" for the master caliper pin is ingenious!
Regards
Andreas
also good for engine mount bolts.
Regards
Andreas
Ok today was spent thinking about the water works.
change of plan the pump will be placed in the dry deck pipes and the pipes on the front will go to the radiator "direct"
here is a mock up.
while i was moving parts about I thought i would check some weights.
Standard flywheel (in parts and missing a few bolts) 7.2kg
so what about the flywheel i am replacing.
alloy flywheel with steel insert and ring gear. steel pressure plate grey spring and fiber friction plate.
just about the same as only the original flywheel
new flywheel assy should be under 5kg
thanks to IDE things can move on a bit
hoses need to be cut to length and pipes made.
exhaust routing adjusted
and stabiliser mounts optimised not that the lower ones actually do anything.
here is a video of how much the lower stabilisers do.
this is with the engine mounts (good but old) done up tight. no head or upper stabilisers so me just rocking the block.
[video=youtube_share;c0vDblRHWdA]
[/media]
Quick Nick^^
The head looks good on it ![]()
Was nice to meet you and had some minitalk!
Cheers my friend!
...and stabiliser mounts optimised not that the lower ones actually do anything.here is a video of how much the lower stabilisers do.
[video=youtube_share;c0vDblRHWdA]Externer Inhalt youtu.beInhalte von externen Seiten werden ohne deine Zustimmung nicht automatisch geladen und angezeigt.Durch die Aktivierung der externen Inhalte erklärst du dich damit einverstanden, dass personenbezogene Daten an Drittplattformen übermittelt werden. Mehr Informationen dazu haben wir in unserer Datenschutzerklärung zur Verfügung gestellt.[/media]
You´re wrong Nick ![]()
The lower stabilizers do a lot but, not the way you simulate it in the video...
Driving loads also make the engine want to move (not only tilt) back and forth which applies shear loads into the engine mounts. These shear loads are taken over by the lower stabilizers ![]()
You even could install an additional lower stabilizer on the LH side, also facing backwards to the subframe to also protect the LH engine mount...
The required bracket for the lower LH side installation... http://www.minispares.com/product/Classic/Suspension/Subframes/Fixings_mountings/21A2785.aspx?190901&ReturnUrl=/search/classic/engine%20stabilizer.aspx|Back%20to%20search
Chears, Diddi
Diddi,
Correct and that is why I have them. But as there is no option to run the left one any more are the MED pinion mount has no possibility of using it as I have before (since the 80s) and I often see people advocating the addition of the lower mounts to reduce engine rock. This was done to show the reality. I would have preferred to have continued with my original set up but not possible.
so what has been going on today. lots of use of a marker pen and a carbide tip.
so innocent and sweet looking
mark grind and repeat until no more rocking.
i think you get the idea.
next was the DSN timing cover. i was aware that some people had been having issues with the cam sprocket position and have been asking about shims for the cam gear which is all not needed..........
so i put the cam assy on and the Crank gear was way proud of the cam gear eeer WTAF
played about with the bearing locating plate new and old. both measured the same and had just barely enough end float. but will do.
so the cam gear is not coming forward time to play about with the crank gear so out with the marker-pen and guess what
well some pics
the new crank has a nice radius on it which stops the crank gear from bottoming out.
gear modified and the gearset line up.
start adding bling
check timing tomorrow.
also set up the primary gear clearance way tight again with all new parts.
so today's annoyance Head stud kits.
even when they are from the same maker you may not get what you think you are getting.
my ARP head stud kit cam with 4 rocker post studs that were the same length. did not think about if till i came to fit the DSN Oil filler cap
cap will not fit. standard black or red ones will fit.
so remove that stud and compare with a new Minispares one
not much in it but enough to allow the cap to fit.
it seems that the kit from MED has four studs the same length while the Minispares one has two long and two short ones.
should be going into the car tomorrow.
So on Saturday this happened
all the breather pipes fitted and there were no conflicts.
I had also previously changed out the reservoir connections to the master cylinders. works much better.
Today was spent attaching drive shafts (the short one was a real pain) and connecting the other water pipes and then looking to the electrics. some things have been moved (coil is where i planed the water pump and the water pump is where the coil was.) so will be making a new bracket.
wiring done, oil pressure acquired brakes and clutch bleed. just needs some fuel adding to it.
tomorrow should be fire-up day.
Good luck then!! Looks good!
