Kurbelwelle 12G1505 + AEG 622 - 623 Unterschied ?
  • FORGING OR PART NUMBERS
    22A62/63Early 850 with oil feed for primary gear, 1.375" tail850cc
    22A298Early 850 thin nose crank, 1.375" diameter tail850cc
    12A670850 crank with 1.5" diameter tail850cc
    12A375
    997 Cooper with oil feed hole for primary gear,stamped 12A375
    or 12A376 on a 12A298 forging with a 1.375" tail
    997cc
    12A298997 Cooper less oil feed hole for primary gear,Deva bush type 1.5"tail997cc
    12A595Early crankshaft forging.Pre1980998cc
    12A1451Later specification 12A1451 forging998cc
    BHM1436A plus 1984 on (12A1451 forging)998cc
    12G82EN16 stamped 12G82,Mini and ADO161100cc
    AEG329EN40B not cross drilled,stamped AEG330
    970cc
    AEG170EN40B not cross drilled,stamped AEG171
    1070cc
    12G1287EN16 1.625" con rod journal,1.22 mains,stamped 12G1288
    1275cc not 'S'
    12G1505EN16 1.75" con rod journal,forged as 12G15051275cc not 'S'
    12G168312G1505 forging some tuftrided 1.75" con rod journal-Mini 1275GT and 1300GT(ADO16)
    1275cc not 'S'
    12G181712G1505 forging tuftrided 1300GT 1.75" con rod journal
    1275cc not 'S'
    BHM1385forged CAM6581 ERA and Metro Turbo ,rolled fillet radii -1.75"con rod journal1275cc not 'S'
    CAM6232Rolled fillet radii on bearing journals, A plus, 1.75"1275cc not 'S'
    AEG315EN40B not cross drilled, nitrided, 1.625" stamped AEG316
    1275cc Cooper 'S'
    AEG479EN40B cross drilled, nitrided, 1.625" stamped AEG480
    1275cc Cooper 'S'
    AEG623EN16/17 tuftrided 1.625" con rod,12G1505 stamped AEG6221275cc Cooper 'S'
  • AEG Kurbeln sind für S-Blöcke und Pleuel.
    ...ja das dachte ich auch , Gußnummer wie im Titel aber angeblich sind da noch eingeschlagene Nummern auch drauf ?..würde gerne nachsehen aber das Teil schnuppert Landluft u. ich komm nicht ran !
